Timmed
Greetings all. I am having the main circuit panel in my home replaced. It's circa 1963 technology, and I'm adding a whole-house surge and generator hook-up at the same time.
There is a 50Amp sub-panel in a detached garage that connects into my main panel. They only ran 2 conductors and a neutral to the sub, but no ground. The neutral and ground are bonded together at the sub, which would be correct in this case. I'm sure this was code at the time, but is no longer.
The work is being done by an electrician and permitted. What I'm wondering is whether the inspector will insist on pulling a ground wire to the sub in order to sign off on the main panel, or if it's grandfathered in? Any thoughts? My electrician can only tell me it "depends on the inspector".
