Is this relief valve needed or required?
Gagecalman
Active Member
Baltimore, MD
This was installed at my friend’s house years ago when the plumber added the plumbing for the washing machines. It just started to drip.
If I open the faucet on the sink it stops dripping but starts as soon as I shut it off so I don't think the pressure is increasing that fast.
He was told it's required. I didn't know so I thought I'd ask the pros.
The house is on public water and has an expansion tank on the water heater.
If it's not required can I install a threaded plug into the bottom?
Thanks for the help!
I would think so. It would be more compact to unscrew the relief valve, and put a plug into the thread that the relief valve is currently screwed into.
If you can unscrew that knurled cap, you may be able turn a screw to raise the relief pressure.
Sylvan
Still learning
New York
Not a great idea as model plumbing codes frown upon a "dead end" on the potable water system as it can cause contamination due to stagnant water
Remove the copper tubing as close to it connects BUT I would take a pressure reading prior to removing any safety devices
What is the PSI of your water while this is dribbling?
Is the dripping continuous or intermittent?
it might be a relief valve set at a lower pressure setting than T and p on water heater (assuming its not plugged) water heater might be in spot that wouldnt be agreeable to discharge from t and p. so they add another one at a lower setting and protect from water damage just a guess. generaly what I see in picture is un needed but gotta be a reason its there
Gagecalman
Active Member
Baltimore, MD
It is just tee'd off of the cold water pipe that runs down to the washers and ends at the utility sink.
There is a T&P valve with a drip tube on WH.
He told me the plumber said it was required. It's been there about 14 years and just started dripping.
gagecalman,
If water drips from T&P where ever it terminates and that's fine with you. than go ahead and plug it off, or re rout the T&P to a suitable location.
I don't think you need a relief valve there .but it might be a good idea. hope you understand why it might be desirable
I think this could have been put in before the thermal expansion tank.
I still think OP should check the water PSI while dipping.
That pressure relief valve could be a common 75 psi used with home wells, and that would be expected to dribble, even if there is a functioning thermal expansion tank. On most of those valves, you can unscrew the knurled cap, and adjust the pressure within limits.
