I have to install a surface-mounted electrical cabinet enclosure on an interior finished wall. Cut sheet attached. The cabinet has “push through rubber conduit grommets” on the bottom, but nothing out the back. I plan to extend a line from a nearby electrical outlet to power it. But what’s a code-compliant way to have a conduit exit the interior finished wallspace and enter this cabinet? I know I can’t just have exposed romex exit the wall and enter this cabinet. Do I add another box in the wall and then exit the box with a short whip section? Or, probably easier is that I make my own hole out the back of the cabinet?
Advice appreciated.
Thank you.
Theodore.
Advice appreciated.
Thank you.
Theodore.
