IrishSwede
Firstly let me thank anyone for taking the time out of their busy lives to help me, I really cannot say enough how much I appreciate it.
We were in the process of attaching our PVC drain (fused to our prefab shower base) to an ABS pipe to attach it to our ABS DWV.
The issue/concern is, after applying the primer and ABS-PVC Transition Cement, we applied the pipe into drain. While I was pushing the pipe in my wife fell over.... by the time I could apply more pressure it was too late and I did not want to risk breaking the weld.
So 3 questions
1. What is the minimum that it must be seated? It is somewhere between 3/8 - 1/2. Unfortunately, if it is not sufficient, we would need a new shower base. I would if you (the brain trust) say I should. I put a cap on it and am currently testing for a leak, but would not want failure down the road....Oatey said if it doesn’t leak now we are ok, but that’s Oatey...I also stupidly added primer to the ABS side, but again Oatey said it would be a “now” problem.
2. Can I add a silicone sealant or epoxy between the top of the pipe and indent so water does not sit in it? What is better if so? Kwik Seal Ultra or JB Weld Plastic?
3. If the brain trust says it is ok to proceed, my next part is to attach the base to the coupler below. I intentionally left it 1/4 short from fully seating in the coupler below as I can only press it in (no 1/4 twist), is this ok? As the base has to be set on a bed of mortar, how long do I have after applying the cement to attach it?
Again thank you for any help or advice on the matter, it is greatly appreciated.
So 3 questions
