How can I remove the aerator on this faucet?
rata221
Hi all. Can you tell me if this aerator can be removed for cleaning. I thought the faucet was a Moen purchased at Lowe's. But when I search the picture it comes up as a Tosca faucet. I cannot see how the aerator is removed, any advice?
Thank you.
GL77
Washington
This is a faucet sold at Home Depot. According to the Q and A, the aerator is not removable.
Tuttles Revenge
Some of the rectangular aerators use a flat hook to insert and pull straight down.
Found it listed as Aquasource Glyndon. 67509W-6027H2
CONTACT US
If you have any issues with your faucet please contact the vendor’s customer support who sell them to you ( Lowes for example ). This website only provides the information related to Aquasource products.
Good Luck.
rata221
Thank you guys for the quick reply. I called The Lowe's Aqua-source number -they said they did not show a separate aerator - so it probably is not serviceable. I may go ahead and attempt pulling it out with a hook or needle nose. I searched on the second picture of the bottom of the spout. A similar Kohler faucet appeared, One owners said removing that piece it did not help. One guy has a video where he solved the sudden no flow problem by removing the low flow restrictor. It was clogged. Perhaps that is causing my problem. Thanks again for the help,
Tuttles Revenge
If the aerator doesn't come out and its clogged, maybe removing the spout and running water through it backwards could clear it. or if its hard water deposits, then maybe some solution to break up the deposits? I never deal with hard water so Im not really familiar with techniques for that.
rata221
Tuttles Revenge. Good idea. I will give that a try - if the restrictor is not the problem. Thanks.
