With this one the corrugated line is not integrated with the valve. It uses a 1/4" nut to attach to the valve. They look similar though, possibly it could be the same brand
The connection at the valve is probably 3/8 inch compression. If your plan is to reuse the same line, you may need a new ferrule (olive).
EDIT: crossout of part that I may have been wrong on) The nut at the top often comes with the fill valve rather than the corrugated supply line. corrugated toilet supply line would be a good search term in a search engine.
The nut at the top often comes with the fill valve rather than the corrugated supply line. corrugated toilet supply line would be a good search term in a search engine.[/QUOTE
The image with the logo is actually a ballcock nut that was attached to the toilet fill valve. The valve isn't one of the push to stops, I've had some problems with those. I guess the ballcock nut and corrugated riser aren't necessarily from the same assembly.
I thought I remembered changing out a fill valve and discarding the include supply nut, because I was using a flex line, which screws right onto the 7/8 thread. The supply nut is used when using a rigid or corrugated supply. Most people use flex lines.
