frankin 1hp pump not starting up, but using electricity
Sprinkler
Barcelona, Spain
Hi, I dropped a 1hp Franklin pump down to around 47 meters, and after connecting the 35 mf capacitor, I switch on and I see the electric meter in the house runs noticibly faster, but the pump is silent. The 2 poles of the capacitors are live when the pump is on. But maybe I'm missing something? All I did was drop the pump in the well, install the capacitor.....is anything else necessary? Like preparing the pump or priming it?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If it is a 2 wire motor you don't need a capacitor. Just hook up the two wires to 230 volt supply from the pressure switch or straight to the breaker.
If it is a three wire motor you will need a capacitor start box with a capacitor and a relay.
Sprinkler
Barcelona, Spain
It's a 3 wire 1hp Franklin. Wire colors from pump are yellow / green (earth) brown, blue and black. First I connected the brown to one pole of capacitor, the blue to the other pole and then continued this blue to line (house) and the black wire directly to the other line in the house. But silent pump. I called the local pump supplier and they suggested changing the wiring like this from pump: black to one pole of capacitor, blue to the other and continue blue to line; brown directly to the other line in house. Obviously earth also to house. They said this would or should work as the pump is 1hp. I gather (?) the smaller pumps would work with the first wiring plan (black wire direct from pump to line.). Thanks.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You can't just hook up a 3 wire motor directly to a capacitor like that. It needs a relay to turn the capacitor off as soon as the pump starts. You need a regular pump control box sized for that motor.
