Converting metal tub tailpiece to PVC
DKenn08
Tx
I purchased a Princeton Americast w/ Integral Overflow to ease the plumbing aspect of it. Seems to be a bad choice as of right now. I've run into finding the right adapter piece to convert the metal tub tailpiece to PVC slip to connect to drain. Will someone point me in the right direction? I found an adapter at Home Depot but the threads don't mesh.
In the installation manual it says final hook up to tub waste can be made using internal threads in tailpiece (1 1/2 tubing 1 1/2--28thd.) or external threads on tailpiece (1 1/2--11-1/2 npsm) for appropriate tub fittings.
Thanks for any help.
viral
georgia
I recently bought the same tub. Was told it is easier to install... What was your solution? Is it holding up?
DKenn08
Tx
Tub went in fine and yes, the integral overflow helped the install.
