Body spray pressure balancing loop
Wakedog
DC
Looking for advice on pressure balancing loop for 3 body sprays. Does/will this pressure balancing loop work correctly? If not what needs to be changed? Thanks.
John Gayewski
Iowa
Looks like this is going to drip water in between uses, probably from the bottom one constantly. I think those shower head outlets should be coming from the bottom of those rungs. Also the supply should come into each side in the middle. The path from each inlet to each outlet should be equal.
Wakedog
DC
Thanks for the advice! It shouldn't be too difficult to turn upside down and replumb.
I think the suggestion was to add the red pipe-- not to turn your proposal upside down.
