Best online store for 10% crosslink resin
Vietjdmboi
Anaheim
After having some problems with low water pressure after the water softener it looks like I need to replace my resin. Any good places to get that online?
I have a 12x52'' tank which is 64,000 grain. This will require 2 cubic feet of resin. Please correct me if I'm wrong. Anything else I should replace while doing this?
Silversaver
Orange County, CA
I did replace my old water softener resin and works great. Somehow it also introduce slow leak issues which simple washer replace solve the issue. While disconnect and reconnect the water softener, a slow leak start between and unit valve head and media tank. I was careless over tighten the valve head and break the media tank. I could have replace to a new media tank but I end up replace with a new 64k unit.
If you have quick connect valve, lube or replace the washer before reconnect. Whatever you do, just take your time and do it right you’ll be okay.
