beolson25
Is it ok (per code) to use 3-way (T-Port) valves to install the softener loops off the main? I'm trying to reduce the number of elbows in the plumbing. It seems like the most efficient way to do it is to have three valves right in the main flow line.
Something like this:
T-Port --------------------------------
Standard Ball Valve
T-Port ---------------------------------
Additional question ... I'm already a bit irritated but let me just ask. I had the softener loop inspected and they require a Backflow preventer(LF009M3QT). It has to be mounted horizontally but my main is vertical at my point of access. I'm trying to figure out the most efficient plumbing path to reduce flow restricting elbows(lets ignore 45s vs 90s in this discussion).
I'm thinking the below(ugly, I know) but I HATE that loop back to the main for the Backflow preventer. Please note, I'm a home owner, not a plumber. I'm most worried about flow restriction.
T-Port -------------------------------- Softener Output
Standard Ball Valve
T-Port --------------------------------- Softener Input
|-------------Back Flow Preventer-----------------|
Main line
Standard Ball Valve
Standard Ball Valve
Main line
