movingsoonMD
- Messages
- 9
- Reaction score
- 0
- Points
- 0
We have Delta faucets in master bath (10 years old) that have a slight leak near the stem, when you slightly press down on ball and turn the ball all the way up (to '12 noon'). Anyway, we are selling the house....don't want to replace the entire unit. Thought this would be an easy fix. Took off ball and white washer(?) around edge of stem...but stem seems locked in place. My wrench is not seemingly wide enough to twist off the hexagonal (and seemingly glued-on) part that attaches to rest of faucet under stem. So how do I take stem off? I assume it's a washer or O-ring that needs replacement but I can't check out where the leak is actually starting from if I can't get the stem removed somehow...
Many thanks.
Many thanks.
