Thread: Hiding cables behind a brick wall
    DIY Junior Member funperro's Avatar
    Jul 2011
    CO
    Default Hiding cables behind a brick wall
    I recently removed some inset shelves from the wall in order to mount a plasma TV. The problem is that I've got cables that I need to conceal, and I'm looking for ideas for a clean way to do it. Normally, I'd just drill into the drywall and run it through the hollow space and have it come back out down below behind the media furniture piece shown in the last pic. In this case, the wall is actually brick. In the first pic, all yellowish painted surfaces are brick covered with a little plaster. So far, the best idea I came up with is to use one of those cable concealers that are about two inches wide... that you mount on the surface of the wall. This would butt up flush against the center lower edge of the wood trim on the bottom of the shelving frame. I'd caulk the edges of and paint over the plastic concealer piece which would be not perfect but OK... but the problem would still be the wires hanging over the ledge in the front. At that point, I'm thinking about drilling straight up into the wood ... or perhaps making a big notch in it that can hold the cables.. then I'd fill in the wood and refinish it. I'd still see an inch of cables in the back... which I could cover with a small piece of the plastic concealer. This seems like a big P-I-T-A. Any thoughts or ideas?
    Name:  finished mount area.jpg
Size:  23.4 KBName:  side close-up.jpg
Size:  42.1 KBName:  close-up.jpg
Size:  30.3 KBName:  front.jpg
    what's on the other side? Can you drill a hole through the brick, use the "cable concealer" on that side and then another hole to bring the wires back in?
    Architect Spaceman Spiff's Avatar
    Salt Lake City, Utah
    What about adding a pair of pedistals made out of wood on the left and right side that have a small chase for the wires? You could match the design of the shelves and paint it to match.
    Spaceman Spiff aka Mike
  1. Remove a brick? Or drill holes through the brick?
    By bassadict69 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2010, 06:13 PM
  2. Remove a brick? Or drill holes through the brick?
    By bassadict69 in forum Remodel Forum & Blog
    Last Post: 10-13-2010, 03:13 PM
  3. New exterior receptacle in old brick wall
    By TJanak in forum Electrical Forum discussion & Blog
    Last Post: 02-01-2010, 07:49 PM
  4. How can a drain pipe in a brick wall be repaired?
    By Onlooker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2009, 05:58 PM
  5. Leak inside brick wall from outside spigot
    By Jan Salazar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2008, 06:41 PM
