Results 1 to 5 of 5
Thread: Combo ball valve/check valve for ejector pump...
    DIY Member hhcibtpaun's Avatar
    Feb 2009
    Pennsylvania
    Default Combo ball valve/check valve for ejector pump...
    Hey everyone,
    I am getting the parts together to finish up my basement plumbing. I am now at the point of getting the ejector pump and associated valves.
    I am going with the Zoeller M267 pump and I need to get a check valve and ball valve. Originally I was going to get the zoeller check valve and a standard issue ball valve, then I found this:
    This is about double what the separate pieces would be, so is it worth it? If any parts fail can they be replaced??? or do I have to replace the whole deal?
    Any help would be appreciated.
    Thanks...Mike
    Dec 2007
    That is a much better valve.
    Most check valves give a helluva thump when the pump shuts off.
    This one is quiet.
    Feb 2009
    Pennsylvania
    Thanks...Mike
    Default valves
    If the ball valve fails you will have to cut it off the pipe and get a new one. Parts may or may not be available, so you might have to buy a new combo and use the parts from it if anything else goes bad.
    Feb 2009
    Pennsylvania
    Thanks for the post. I ended up ordering, so now I just need to wait...
    Mike
