Results 1 to 6 of 6
Thread: Different standpipe sizes?
    DIY Junior Member mike04gt's Avatar
    Dec 2008
    Chicago, IL
    Default Different standpipe sizes?
    Hey All,
    Just wondering if anyone knows if they make a standpipe back seal in any other sizes than 4"???
    My drain opening in the floor is 4.5", but I cannot locate any other larger sizes online or at any of the local plumbing stores.
    Thanks~
    Aug 2008
    Gonna need a pic so we can see the type of pipe you have.
    Default seal
    That's because there is no 4 1/2" pipe. The next size above 4" is 5" and it is such a rare beast, that 6" is most likely to be found.
    DIY Senior Member gardner's Avatar
    Apr 2007
    Ontario
    I think he's talking about the opening in his floor drain, not the pipe it's connected to.
    From the other thread where this all came up http://www.terrylove.com/forums/show...t=25408&page=3, I would assume this is an old cast iron drain installed originally in the 20s or so.
    Nov 2008
    Chicago, IL
    That is 4" ID pipe Go ahead and buy the stand pipe adapter, tighten the screws a bit so its will fit in snug, once you get it in the pipe tighten the screws, the rubber will expand enough to make a seal.
    Dec 2008
    Chicago, IL
    Quote Originally Posted by gardner View Post
    Yea, its an old cast iron floor drain that measures an odd 4 1/2" opening size.
    Quote Originally Posted by SewerRatz View Post
    Just wanted to make sure it can fit before I buy one, thanks alot!
