a quick fix gauge just pop it on to the air inlet valve on the pressure tank. this will tell you the line pressure. dissconect the pipe work and run the pump into a bucket and time it how long it take to fill 3 gallons divide this by 3600 x 3 is gph of pump. work out pwl and this will tell you if pump is on par with what it should be .
cheers max
