moeronn
The hot water faucet valve stem (PricePfister) in the bathtub was leaking. Note, this was the stem leaking, not leaking through the tub spout.
They turned off the water in my condo complex today, so it was a good time to change out the valve. Well, I replaced it and now the new valve leaks the same way. Are there adjustments that can be made on the stem to stop the leak? I also replaced the seat behind the stem. The water has been turned back on (duh, or I wouldn't know it leaks) so I can't really remove or replace the stem now without calling out the association plumber to turn off the water again.
Any suggestions are greatly appreciated. Thanks.
