Will Dahl 611-41-31 angle stopvalve this do the job?
I am planning to connect from 3/8 OD soft copper tubing to a common toilet supply line, as well as 2 lav supply lines (3 valves total). I will use the smaller soft copper because I will be fishing from the basement through a finished plaster and metal lath wall.
1. Will valve this do the job?
Dahl 611-41-31 Retrofit Valve 3/8 OD Fem. Comp X 3/8 OD Comp
2. What is the distinction they are making between "female compression" and just plain "compression".
3. Is there a better alternative for that job?
4. Does the word "retrofit" just mean that it would not be a good choice for new construction, which is what I suspect?
Nope.
Not without a 3/8" compression coupling to connect the 3/8" copper to the end of that fitting.
You could also pick up a standard IP stop and reduce with a 1/2" MIP x 3/8" comp.
Or you could go big and fish 1/2" up there which would be 5/8" OD.
Thanks! That sure opens up the availability of stop valves.
I was searching high and low to try to do it with one piece. I did find the Aquaflow V-106-A. That adapter method may actually be preferable now that I think about it.
My first try did not work. It leaked at both ends at the compressions. I don't know if I tightened right, and if I did it wrong, I don't know if I over-tightened or under-tightened. But by the time I pressurized things, the nuts were really loose. I am sure I did not leave them loose.
The copper I used was identified as refrigeration tubing, rather than type K, L, M. It was what was readily available.When I bought it, I figured refrigeration has high pressures, so it should be OK for water. Well, not for me. I measured 0.030 wall thickness on a caliper after the fact. If I try the 3/8 OD compression again, I may order up some type K. Not cheap since they don't sell only 10 ft at a time. Or maybe I will use 5/8 OD, which is easier to find in K and L. Fishing that has to be harder.
For the toilet I ended up fishing 1/2 PEX and using a Sharkbite angle stop. No elbow-- just an unsupported bend. I wish they had a better system for rework.
Update... I tried compression again. This time I tightened, and waited, letting things flow. I think it is going to hold, and I should have just retightened my first attempt a few times.
After taking out my first try, I expected the tubing would be constricted where the olive pressed down. Nope... I could not detect a deformation.
Anyway, I did come up with some methods for fishing the guide cord that preceded the tubing. I used an LED rope, that was easy to see through the hole in the wall. I lassoed it, and pulled the cord down.
I am waiting before attaching the stop valve to the wall so I can watch for a possible leak, and to give a final tighten even if there is no leak.
