I am planning to connect from 3/8 OD soft copper tubing to a common toilet supply line, as well as 2 lav supply lines (3 valves total). I will use the smaller soft copper because I will be fishing from the basement through a finished plaster and metal lath wall.
1. Will valve this do the job?
Dahl 611-41-31 Retrofit Valve 3/8 OD Fem. Comp X 3/8 OD Comp
2. What is the distinction they are making between "female compression" and just plain "compression".
3. Is there a better alternative for that job?
4. Does the word "retrofit" just mean that it would not be a good choice for new construction, which is what I suspect?
