FirstHomeGirl
- Messages
- 3
- Reaction score
- 0
- Points
- 0
Bought my first home in September. This being spring I planted a lot of landscape today. Also watered some areas where I seeded grass. All told I was probably using the hose for a good 3 or 4 hours today. While the sprinkler was running I also took a shower. No problems so far. Then I left the house. When I came home about 5 hours away I went to turn on the faucet. Water came out fine for aprox. 5 seconds and then lowered to a trickle. I checked all the other faucets inside the house...same story. and then only barely a trickle. I looked inside at all the pipes. No leaks. I looked at the well tank ( I think it's a WEL-X-Trol.... I'll try to find specifics later) and I looked at the pressure sensor next to it... was reading at 30psi then climbed up to 60psi and has now settled at 45psi and is not moving. Through all this checking, the pump did not come on once.
I've been trying to find things on the internet.. but no luck so far. I also just noticed when I flushed the toilet... the water that trickles out to fill the tank was bubbling, and it seemed like there was air in there as well.
Any ideas where to start? Any other details you need to help me out??
