kawizx62003
This is a small multifamily property. The well and pressure tank is in the woods about 350 feet from house. My problems started when the pressure tank was stolen. That was replaced but since it didn't have a low pressure cut off switch, the pump soon burned up. SO of course the well was run dry at that point (they cut the braided hose and took tank).
Replaced the pump which was a 1HP with a 3/4 HP as it was only one available in the emergency. Everything has been fine for 2 months. Last few days tenants complaining of no/low water. Yesterday I went to check it. When I got there, the pump was running and pressure was zero. The gauge was pretty beat up so I replaced and replaced tubing to gauge. No help. Replaced pressure switch as I had a spare, no good. Pump made it to cut off once and then couldn't again. Cracking the valve, I'd get a normal good stream, then sputtering with air and then dry.
I removed check valve and ran pump straight from well. Water would run but with some air and then eventually stop (maybe a min). Then I'd cut breaker and flip back on, depending how long it was off would depend on how long it ran until dry again. Put back together so they had water and I see even over night it did not reach cut off pressure.
The well pipe is about 200+ deep, that's all I know from pulling it.
I am very reluctant to call a company as there is city water available but of course that's at least $1000 tap fee for one meter, which sticks me with a large bill for 4 units each month and no one caring about water conservation. 4 separate meters would be $4000.
So judging by that info and the video, is there any other possible cause besides well running dry? Should I add 10' or so of poly pipe?
