I have a Myers jet pump on my well. Pump will run till gauge gets to 55 or so then stops. Pressure will slowly drop for about 8 min til it gets down to 35 and pump kicks on and runs back up. This happens when their is no leaks or water use in the house. A well guy came out and said I probably had a bad valve in the well allowing water to drain back into well. I live in MN so ground is frozen and he suggested I put up with it until thaw and then I could have it repaired if I wanted. Is there any other options either temporary or permanent? The pump running every 8 min may drive me nuts before spring!!
