Wall hung toilet in 2x4 construction
katwhite
Maine
Hi:
I have a wall hung toilet meant for a 2x4 wall. I recognize the that, in order for this to work, the 3" drilled hole for the waste pipe must be dead-on-center of the 2x4 plate , leaving only 1/4-1/8" on each side to spare.
My plumber does not think it can go in the 2x4 wall. While not what I'd wish, thats what I have in this renovation, and without going into room descriptions, I cannot fir-out the wall.
Happy for advice and instruction.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Of course it can't fit decently. 2 x 4 carrier, no matter the mfr, is soo hard to do repairs, nearly impossible and you will regret it.
The pipe is 3.5", the wall is 3.5" and you connect the adapter coupling below the floor...so your floor plate is obviously cut completely. And the required nail plates cause bulge and don't forget, when you sit on the WC, it is all cantilevered so expect flex off the wall...that is an absolute given unless you somehow use a very solid wall board
Tuttles Revenge
We've installed in wall tank toilets many times in 2x4 walls. It just takes extra diligence to get it done correctly. Install the carrier exactly flush with the front of the studs and match up the drain through the bottom plate to match.
While they are harder to work on internally than any other tank, they're not really that hard once you get familiar with them. I've worked on Geberit and Toto doing repairs and haven't had any real problems... just don't drop anything in them.
