I had a leak from my upstairs tub and had to remove part of the wall to get at it. It turned out to be leaking from the slip nut in the horizontal pipe that connects the drain to the overflow riser. A simple fix but I was surprised that such leakable parts were sealed up behind the drywall. Is this normal? Would it be better to replace to system with glued fittings?
