Hi
dyi here. I installed a new high dollar pfister faucet on a bath vanity and it was easy enough except the drain. it leaks at the washer set. things i have done to stop it.
1. reread the installation instructions and did two complete remove and installs on the drain
2. it says hand tighten and i have had to use channel locks because its a metal nut but no matter how tight or not it still leaks.
3. there is a gasket right below the top and then a fat rubber washer, a flat nylon washer and the metal nut. it says not to use anything like putty because it would degrade the material.
i have laid and watched it and tried different torques on the nut and done this for several hours over several days. its laughing at me
i wonder if the surface of the sink material at fault, it drips from the same area, sink is a cast material. should I dry the area and fill area with silicone and tighten it down and wait 24hours and check for leaks or should i try and buy a push drain that will allow putty. what would a plumber do in this situation.
thanks for any advice on steps to take,
