Set screw stripped
Guzak
Houston, TX
Can someone identify what brand, if this is Moen, Delta? It leaks and needs a new cartridge.
Also I'm using a 7/64 Allen wrench on this set screw, it bites a little and strips. Any advice on a solvent that might help loosen it and a way to get a better hold to turn it?
Many thanks.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Delta brand. 1300 and 1400 series cartridges if the handle rotates. No liquid penetrant will really help.
If the handle operates like a joystick, then it is old Delta ball mechanism.
WorthFlorida
Solutions
Orlando, Florida
7/64 = .109 inches. .109"=2.77 mm. Try a 3 mm Allen wrench. It just might fit for a tight fit.
Tuttles Revenge
And tapping in the 3mm to get really good purchase.
When that fails a small easy out might work, but if its brass it won't.
I recently had to drill out some stuck set screws.. Be careful not to drill too far. I then re-tapped new threads and inserted a new stainless set screw
