Hawksnest101
Heat only system/ thermostat. Sensi needs a common wire to power same which I have and traced it to the hot water furnace. Can I connect the C (common wire) to the transformer located on the furnace to get the required 24 volts? If so to the terminal that has a red wire connected to it? Thank you
