lol Rancher - the CSV cure all. I'd actually like to try one, the constant pressure sounds tempting. I'm running 40/60 and the tank psi is 38. I've had this Pumptec problem since day 1 (well install was about 3 yrs). I've never been able to coincide any environmental conditions with the times that it trips, other than 80% of the time it happens while in the shower with soap in my face. Franklin Electric says that upon cut-in, it would only take the slightest power loss to trip an 'overload' on the pumptec. I've only actually witnessed the Pumptec tripping about 3 times. Every time it was at cut-in, I've never noticed it tripping after the pump was running.
If anyone's bored, here's the email conversation with Franklin Electric support.
If anyone has any ideas I'd love to here them.
Email conversation with Franklin Tech Support:
I have a Pumptec Plus that was installed new with my well system about 3 years ago. Since the initial installation I've had a problem of frequent tripping. I'm getting the flashing yellow light indicating an overload. The unit might be fine for a couple of days and then trip again. The problem has seemed to get worse over the past month and I will get at least 1 fault a day. The unit is located about 300' from the house so we simply cycle the breaker at the service panel to reset it. I've checked the voltage (Fluke multimeter) at the unit and it stays within the range of 243V to 247V. When the pump starts, the voltage will drop for an instance to around 225V but then returns to about 238V while the pump is running.
Could this be a defective unit or is it more likely a voltage drop or other problem? I've tried calibrating the unit several times following the instructions in the manual. When I press the reset button to take the "snapshot", the pumptec will attempt to run the pump (flashing green) and then immediately go into an "overload" fault. It does this everytime I attempt a calibration. This is the only thing that makes me think the unit could be defective. I have no problem with purchasing a new unit, but I'd hate to buy new and still have the same problem. I do not want to bypass the unit due to a low yeilding well. Any ideas or help would be greatly appreciated.
thassler,
What type of motor do you have this Pumptec-Plus on? If it is a 2-wire motor (w/o a control box) the symptoms of the overload trip after calibration is normal. The reason for this is the Biac switch will not reset in less than 5 seconds and the Pumptec-Plus will stop and restart after calibration quick enough that the motor will not start and trip the Pumptec-Plus out for overload.
I am wondering if there could be a momentary power outage and the same symptoms (as when you calibrate) may happen to the Pumptec-Plus when this happens. This could also be caused from a bouncing pressure switch or control relay.
Thanks for the response. Yes, it is a two wire motor so that would be the reason for overload trip on calibration. I havn't noticed any power interruptions at the times it trips. Murphy's law seems to follow me, so it only seems to trip when I'm in the shower <lol>. The Pumptec is wired in 'after' the pressure switch so is powered off until cut-in pressure. Could that cause any problem? Should I try wiring the pump-tec 'before' the pressure switch? Due to a low yield well, my static level fluctuates quite a bit. Should I try to calibrate at highest static level or wait till it drops after some water use. Well is 400', static level is about 125', pump sits at about 375'. Should I be looking at voltage drop/fluctuations? Grasping at straws here, I'm wearing the breaker out on the service panel <grin>.
thassler,
The location of the Pumptec-Plus should not make a difference.
I would calibrate the unit with the water table as high in the well as possible. This will give you the best protection for under load and it should never see an overload since a fully recovered well is the highest load it should ever see.
Your comment about seeing it trip at turn on makes me wonders if the pressure switch is bouncing and causing the problem. It only takes a momentary power interruption to cause a problem. You might want to look at replacing the pressure switch.
I am just like you fishing for a possible cause of the problem and a solution.
Thanks,
Water Systems Service Engineer
Headquarters
