kingfisher
- Messages
- 17
- Reaction score
- 0
- Points
- 0
Hello,
I have been using a 1/2 hp Flint and Walling shallow well jet pump. Outside of a priming problem I encountered this last week. (I found the leaking joint on the vacuum side) it has worked fine.
Just wondering what performance differences I would have with a 3/4 HP pump. The particulars of my set up are:
1 1/4 pipe; static water height at 19 feet; well point depth 31'; 12 feet of water in pipe; utilize bladder tank set at 35 psi; cut in on pressure switch 40 psi and cut out at 60 psi.
Would welcome any thoughts and recommendations.
Kingfisher
Kingfisher
