Hello!
Bought a 20 acre farm. Built the garage first, 90% complete. Plan to build a barn and 2300 sq ft home, all separate buildings. The plan is to make the garage the center point of the utilities, gas, electric, cable and water. At the point to install the well water into the garage. My question is what would be the recommended pressure tank size to put in the garage which would feed the garage then send water to the house. The house is to be 50 feet corner to corner from the garage. Also, what would be the estimated water line size from the garage to the house?
Would it be helpful to install a second pressure tank in the house with a check valve between the two?
Any recommendation or advice would be greatly appreciated!
Thank you,
Thank you,
