So any brand, but type liquid filled?I would opt for a liquid filled water pressure gauge.
Explain bottom of the tank? Pressure tank?So any brand, but type liquid filled?
This gage is at the bottom of the tank but I want one also to measure when the tank is valved out.
Some folks will install a ball valve before the gauge so the only time the gauge sees the pressure is when the valve is opened.Would putting a gage directly on the top hole of the pump ruin the gage because of the constant pressure swings?
Not necessary. Closer to the pressure tank would be better.Now I'm wondering if it is necessary that the 1/8" tube be attached at the impeller, instead of anywhere in the piping?
Having connections on the pump is a matter of convenience, not of good design. It lets the pump manufacturer ship a complete DIY solution in one package. Best practice is to make the connections at the tank Tee.The pump has outputs on top & to the side, but why else would they provide a small hole on the back of the impeller?
Elevating the switch and gauge on tall 1/4 inch riser pipes gets them up to keep them dry.
Showing vibrations is a good thing when analyzing a system. Same sort of thing with an analog volt meter where a quivering needle gives clues....and show every vibration in the system
To do what you are asking, you need 1/8 ID tube. You need a clamp that can clamp down on the ID. I don't have a product suggestion to do what you are asking for.Cannot find the proper tubing. Searching for water pump pressure switch tubing gets all types of tubing, and no info on if it the correct type that will expand a bit when heated & then shrink on the barb.
You already understand that we were thinking you should want something else.
Got a non-google URL? G is evil & I don't allow it on my computer.That works, but we all forget about snubbers and GOOD pressure gauges. WIKA is my gold standard and US made - High priced but many NOS items on Ebay not much more than junk imports. My China gauges were lasting a year and the WIKA's still going after 5+. https://www.google.com/search?q=pre...3j0i22i30l6.4844j0j7&sourceid=chrome&ie=UTF-8
But it doesn't say if OK for potable water, a lot of gauges are not.
Get a digital caliper. You are next going to say it may not be a 1/2 inch NPT thread, but maybe 3/8 or 1/4 NPT.It might not be exactly 1/8... maybe closer to 1/4" OD ? Maybe x/32" ? What is the standard ID for a barb on a 1/2" fitting?
