Popup drain leaked on first test
Elijahwww
MA
I installed a set of Danze faucets in my new bathroom vanity, but the metal drain is leaking on both sinks. It is leaking from either the tailpipe where it is threaded into drain collar or from the collar itself, I can not tell.
The collar came with rubber washer on top and bottom, so i did not use silicone or putty.
For the tailpipe I used about a foot of teflon tape.
The picture below doesn't show the top rubber gasket that goes under the flange, but the unit came with it.
What did I do wrong?
http://www.danze.com/file.aspx?DocumentId=299
Either pipe dope or plumbers putting on the threads of the drain collar. None on the rubber donut below the sink.
The tail piece either gets pipe dope or a little tape.
I have never seen instructions with faucets mention this, but it keeps us employed.
Elijahwww
MA
Thank you all. I will try the putty next.
HJ, the threads had that much slack, that I made 3 rounds of tape and i could still thread it with relative ease.
Elijahwww
MA
That worked, plus more putty on the drain collar threads, where-about the bottom rubber washer is. It wasnt keeping the seal otherwise.
Is there a safe torque spec for the lock nut? I was afraid of cracking the sink or bending the flange.
Elijahwww
MA
Still no leaks, thanks everyone
