Pop up drain plug not coming out
Jen24
South Dakota
I have a drain plug like just like the one in this video (
). I have followed the directions in the video and it still won't come out. When I pull on it to remove it, it sounds like metal hitting metal. Almost like there is a bolt in the end not letting the plug come out. There is no screw to remove anywhere. Any ideas?
WorthFlorida
Solutions
Orlando, Florida
With the stopper up to allow drainage and with a long nose set of pliers, place the long nose under the flange to force the flange up, then turn the knob. A screwdriver might also work.
Tuttles Revenge
Some of the stoppers, the knob on top of the flat piece comes unscrewed to reveal a slotted screw underneath.. That style you would lift half way and turn the knob in place
there are a few slightly differant methods. mostly i seen the removeable cap with screwdriver slot underneath . but googled and found other type as well
Tuttles Revenge
Here are 3 common lift and turn style stoppers and their methods of removal.
