veramax
I apologize for not having time to do thorough search on this site.
I have a Champion Max 4 toilet from American Standard, with the Champion self-close seat. The plastic seat bolts never stayed secure, and after falling apart numerous times, I decided to make a custom bushing out of heavy duty duct tape to surround the plastic bolt and fill-in the extra space in the porcelain holes. It worked beautifully for the first few years. The bolts remained firmly in the porcelain holes, keeping the hardware secure.
I like to fully remove the seat to clean the toilet. My custom-made duct tape bushings are not going to last forever, and the adhesive is starting to turn gluey. I was thinking about an upgrade.
Does anyone know where I could find a rubber bushing piece to use in this application? I would want the plastic bolt to either slide into the bushing cleanly, or screw into the center with the thread catching some of the rubber material. And then I would need the rubber bushing to fill most of the porcelain hole. I could always add duct tape to the bushing to make the fit tighter, keeping the adhesive away from the screw thread.
Is bushing the correct term to ask for? Where would I find such a product? Can anyone approximate the measurements I would need? Interior diameter of the bushing and exterior diameter, approximately.
Does anyone have any other suggestions for creating a tight fit that's easy to take apart when cleaning?
Thank you.
Thank you.
