larryruest
Hi, Finally found a kick*** forum about what I had researched for weeks...I had upgraded today from a 1/2 hp 30 year old twin type deep well jetpump / an old steal tank to a myers hj75D deep well jet pump and a fiberglass 30 gallon air pressure tank...
First of all in the myers jetpump instruction it was only talking about 20 - 40 psi / 30 - 50 psi setup... I want the most pressure possible since I have a house with three levels and the main bathroom is on level 3... On level 3 there is not a lot of pressure but on ground 0 (basement) there is a lot of pressure... Piping is a factor here since I have copper pipes which are really small and a lot of 90 degrees....
So I wanted to go with the 40 - 60 psi setup (screw myers handbook)
So I inflated the tank to 36 PSI as recommended in the tank handbook.
I hooked that all up and the pressure was set to 20 - 40 on the pump. So I played with the screws and now it is set to 34 - 58.... I tried to put it around 60 or 61 but the pump runs a lot of time before getting to 60... Is that normal?
Also the screw on the regulator, I tighted it too much and there was no water coming out at all fom the sink... How can I set this up? Is that a factor on how much pressure I can get?
What is the average time a pump should run between cycle? My pump if it is running and there is water continuously flowing, it looks like it would never stop...
Also the gauge when the pump run is oscilating and is not steady like the gauge i' ve seen online...
Would you have any recommendation? If I could raise it higher than 60 PSI, I would be really happy since the presure upstaires will make sense.....
