DonL
I have problems with my water well again. Last repair was about 7 years ago, When I replaced the packer/jet assembly.
1 HP 3 stage pump with flow/pressure regulator.
Volume is low and pressure is about 20 psi max.
When I adjust the regulator to send more water to the jet, 20 psi is the max that I can get.
I am trying to guess if it is the pump itself , Regulator or the Packer assy at fault.
I am pretty sure it is not a casing or leathers leak, Because it will hold at 20 psi over night with pump off. I see no water leaks top side. The 40 foot well should have plenty of water.
At first I thought the jet was plug, But seems that the jet pressure would be higher if that was the case. ???
Any clues on what the problem may be ?
Thank You in advance.
