bricktop
Hi all, new member here, and recently new homeowner. This place looks to be a great resource I'm sure I'll be here often as we continually get this place back in order.
To preface, the previous owners of this house lived here for 3-4 years and, from everything we gathered, did not invest in or maintain anything. The house is on a well, unsure of the depth currently.
When we inspected the house, there was a rudimentary water test, which was positive for choliform, but the UV light was out, and was for who knows how long. We made them replace it before purchase.
The softener did not appear to be drawing brine from the get-go, i'm not sure if it's working at all. I'm guessing the resin bed is pretty fouled at this point. It looks to be quite old - a Flotrol mechanical valve? Most all of the labels on the tanks are illegible. No labels indicating service info or who installed.
There also looks to be a venturi air injector before and after the pressure tank, then a settling tank, then some type of backwashing filter. Also unsure if this is functional, there looks to be some pieces missing from the controls.
We recently had a more thorough water test of the water direct from the well (save for the first-draw numbers, which are from the kitchen faucet), which is attached.
We're looking at getting this all working again. I'm mostly concerned about getting the iron and manganese levels down, the water does taste somewhat metallicy. The hardness isn't too objectionable now.
We didn't have the post-treatment water tested professionally, but we did get a Hach 5B, and it appears the water is the same hardness before and after the softener.
When drawing the water samples for professional testing, it was very brown at first. I suspect iron that oxidized from the injector had precipitated and settled in the pressure tank. The actual sample, which was taken after 7-10 minutes of running the water, was still rather turbid.
I haven't seen any evidence of iron bacteria. I suspect the iron filter or softener would have clogged by now if we did have it. Based on the choliform results, we might try shocking the well when the snow thaws.
To the point: based on the water test results and the age and state of the equipment, would it be worth it to fix up, perhaps replace the valves and media in each, or to replace it altogether? I'm not against spending the money for new equipment if it's quality and worth it in the long run. I would prefer new electronic valves, especially a metering one, if these aren't already? (I doubt it?)
Should we stick with an iron filter, or remove it and just fix up or replace the softener and count on it for iron and manganese reduction? Would that be too much of a pain to maintain?
Or, replace/service the iron filter and drop the softener altogether?
Thanks in advance for the help!
