thediver
Hi All,
I have one of those boat anchors a pre 1998 Rialto Kohler K3402 made in 1992. Thanks to this forum I was able to replace the entire fill valve system due to it constantly running or leaking at the top three screws.
Now I have a problem with a leak at the flush ball (or flapper). It leaks at various speeds. I took it out to clean the residue off of it to make sure it wasn't that since that helped in the past. This time it didn't work and the leak is actually worse.
I need a replacement and have tried two different Korky replacement parts. Both didn't work since the size was off by a tad. Has anyone found a replacement flush ball that works with these toilets? If so, I would be grateful for some advice.
Thanks in advance.
Amy
Thanks in advance.
Amy
