joe shedler
Hi guys,
Im out of town, in a house about 40 years old. I have a sandpoint well at 18', a run of about 30'-40' to the house a pump inside that fills a pressure tank (about 5gal I think). I have poor pressure at the faucets, tub, and shower, but full bore at a tap thats about 6" from the pressure tank. This leads me to belive I have hard water build up in my pipes (yes I do have hard water here )
I was thinking the cost to replace my pipes would not be cheap, including drywall repairs, and a tub surround that might have to come out in the replacement. So I wondered if I could fill the pipes with CLR and let that try to remove some of the hard water build up and save a bunch of money.
Is there a reason to not do this? As in would it harm any of the pipes, or faucets ect. or would it simply not work? Here is a pic I made showing how I was planning on getting the CLR into my lines.
https://imgur.com/a/THDyQtO
I would need to add the shut off valve, and tap in that picture, but I was thinking having the shut off valve so close to the pump would mean I wouldn;t even lose my prime, and the pump should draw the CLR in through the hose.
Thanks to anyone who wants to reply, your time is appreciated.
