How to use a basin wrench
obama
ca
seriously i am a retard or what? i dont know how to use it. i cant tell which position to tighten and to untighten. and i cant tell if i am looking at a nut from underneath thats attached to the bottom of something, which way to twist to take it off. from bottom looking up, clockwise or counter?
DonL
Houston, TX
Counter Clockwise.
Right tight, Left loose.
Good Luck on your project.
Bluebinky
Des Moines, WA
Here's the thought process I use when working with threaded things...
With right handed threads, turning something clockwise makes it go down. Looking directly at a bolt or nut, down means tighter.
However, when reaching underneath the nut needs to go up (towards you) to get tighter.
If you can't figure out which way to set the basin wrench before hand, put it on your finger and turn it :cool:
quote; when reaching underneath the nut needs to go up (TOWARDS YOU) to get tighter.
IF he can use a basin wrench WITHOUT being under the sink, then he is a real professional and would not need to ask this question.
BobL43
DIY Senior Member
Long Island, NY
Is your issue which way to turn the nut or which way to swivel the moveable jaw on the wrench? Tuning the nut in the right direction was mentioned by Don, but using the wrench can be figured out by seeing how your finger will get twisted if you stuck it into the wrench's jaws. Of course, you do not want to twist off your finger, just to find out which way it will be gripped and which way the wrench will not grab it, but slip around it. You are funny, not stupid at all.
Oh! Bluebinky already said that. and I did not see it at first.
obama
ca
one issue i also have is the claw never locks, so when i twist, the claw just gets larger and loses its grip on the nut. ??
quote; left-right and clockwise-counterclockwise are reversed, but up and down are not?
Everything is relative, my friend, it depends on WHERE you hold the mirror. If you hold it overhead then up is down, and vice versa.
