Hose Vacuum Breaker Removal & Replacement
knuckle buster
How do I remove an old and leaking hose vacuum breaker from an outdoor sillcock? The old one was attached by screwing it on the sillcock threads and tightening the set screw and breaking off the set screw which left a rusty stub in the set screw hole.
Thanks, Knuckle Buster
ckl111
Home Builder
Ontario
The set screw was not supposed to break off.
You need to drill out the screw to allow the vacuum break to unscrew. Drill slowly so you drill as little as possible into the hose bib threads.
vb
The screw was intended to break off. Either cut a "V", which includes the screw stub, in the vacuum breaker, and knock the V out which will also remove the screw, or replace the hose faucet.
ckl111
Home Builder
Ontario
Beg to differ with you on that!
It is a tamper-proof design that is supposed to ensure that once installed it is not removed.
Sorry for the mis-information. :eek: The ones I have bought in the past had a fairly large bolt as a set screw so I didn't think something that big was mean to break off.
Redwood
yep! There is a notch in it so it breaks off when the right amount of torque is reached.
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
I received a call once from a home owner saying he really screwed up. He put on the vacuum breaker and tightened the set screw and it broke off. I tried to explain to him over the phone that is what supposed to happen. I ended driving there and showing him that it was normal, he was kind enough to pay my service call for some plumbing 101.
