Fleck 7000 SXT Setup Question
John Edwards
Guys any chance I can get your coaching on my programing of my water softener?
I am on a private well
Water hardness is 10 GPG
Iron is 1.0 PPM
I have a resin tank with 2.0 cu.ft. of 8% cross linked resin
The tank has a Fleck 7000 SXT valve
BLFC = .125 GPM
Programed as follows
Standard Valve Type - DF2b
Control Type - Fd
Unit Capacity - 48,000 grain
Feed Water Hardness - 15 GPG = (base of 10 +5 for 1ppm of iron)
Reserve Selection - SF
Safety Factor- 10
Day Override - 14
Regen - 2:00AM
Regen Cycles
B1 - 10 mins
BD- 60 mins
B2 - 6 mins
RR- 10mins
BF-20 mins
Flow meter type - t1.2
Your input is greatly appreciated, Thank You in advance!
BF= 8*2cuft/3/0.125 = 42.667 minutes
Round to 43 minutes for 8 pounds of salt per cubic ft and C=48,000 as I see it.
I don't know if SF or other numbers are right. SF depends on water useage pattern.
John Edwards
thanks guys appreciate the help I have modified the programming based on your feedback
You may want to shorten up DO (day override) because you are using the softener to treat that 1 PPM of iron. I don't know if there is a rule of thumb about how to set DO in the face of 1 PPM of iron. Maybe 8 days seems to be what I have seen suggested.
