nomorewell
- Messages
- 7
- Reaction score
- 0
- Points
- 0
Three summers ago, I drove a 1.25" point down 22 feet and got a good driven well for watering the garden. I could run one oscillating sprinkler for two days straight. I use a 1/2 hp Wayne pump with a pressure tank and, in winter, I take the pump inside.
Last week, I hooked everything back up, but got no water except for a few drops. There was six feet of water in the pipe, but apparently no recovery. So, I connected (sealed) a garden hose to the pipe and turned on the city water for a half hour, hoping to clean up the screen. Now, if I put the hose a few inches into the pipe (not sealed) the well will take in 4 gallons per minute.
My neighbors have driven wells 200 and 250 feet from mine and they are running fine.. Both use 1/2 hp pumps, but they have drop pipes down into the 1.25" driven pipes. They have no pressure tanks or check valves. They just prime the pump as needed.
I could have an air leak somewhere, and wonder if using a drop pipe might solve the problem.
Thanks for any advice.
Edit: I finally got the sucker going and had it running for an hour. Was pumping just short of 4 gal per hr at 40 psi with the ball valve on the outlet partially closed. Every so often the pump made a noise like air passing through, and the gauge would fluctuate slightly. Filled a large glass, and the water's clear as a bell, but full of air bubbles size of a pinpoint.
