cleaning old solder
Mikept
DIY Senior Member
CT
If i took a wrench and rotated the stop to a different direction would it leak?
Mikey
Hansville, Washington
If you rotated it that way ("took a wrench and..."), it probably would. If you turned the water off, loosened the compression nut, rotated the valve, and retightened the compression nut, it should be OK.
Mikept
DIY Senior Member
CT
After i torqued the nut 3/8 turns past finger tight, i noticed the stop was angled past vertical so i turned it just a bit with my wrench. I suppose if i had turned it more it would have leaked after.
