Jefrf
My kitchen sink tends to back up because the line runs into original pipe (built in 1942) below the concrete basement floor. I snake it occasionally but it still gets slow. Who knows how much gunk has built up over 80 years or what the integrity of the metal pipe even is at this point! This causes it to back up into a small bar sink in my basement which shares that line. I decided it might be worth running about 20 feet of new 1.5" PVC from just below the kitchen, along the basement ceiling joists, over to where all of the other plumbing runs from three bathrooms, and close to the main stack. This is all nicely hidden in my basement laundry room. Just about where I would want to pop the new pipe into that room is a 3" line coming down from the second floor bathroom, transitioning to horizontal along the basement ceiling with a nice long sweep combo wye and 1/8-bend, and a clean-out threaded behind the sweep. (Shown in photo) The new kitchen line would be right in line with that clean-out, but I don't know if I can just run a 1.5" line straight into that. I suppose I'd have to provide another clean-out if I did. I'd also need to find the right fittings to go from female threads of the 3" clean-out to my 1.5" PVC.
Another option would be to leave the clean-out where it is, and running my kitchen line a little past the sweep location, maybe a couple of feet, and use a wye fitting to tie the 1.5" into the 3" along the horizontal run. The reason I'd rather not do this is because I don't think I'll have room to move the 3" line apart in order to fit and glue in a new wye fitting. Whereas working only on the open end where the clean out is would provide opportunity to start my glue joints.
I appreciate any advice here.
