I've posted a couple threads about my 2" well. I decided to have a guy with a truck pull the drop pipe. The casing appears to be 96' and the static water is at 11' from the surface. There was only one stick of galvanized pipe with the jet at the bottom with a check valve. The well guy and I poured water down the casing and it didn't completely fill it up, but it did rise in the casing. The well guy said that is an indication that the well is bad. He said it might work to put a stick of schedule 80 on the bottom of the jet (He said the jet looked good so we just replaced the leathers and cleaned it) and put a new foot valve at the bottom of the tailpipe and sent it back down the casing. I should say this is just a one bedroom, one bathroom weekender in which I would use a very low volume of water. Unfortunately, like before, the pump will only pump a very small volume of water (like a crimped garden hose). He said it might be a screen well and it might work to pressurize the well casing with air using a high, high volume air compressor and if the screen is clogged, it could blow the screen out and cause the volume to increase. Is anyone familiar with this technique and is it worth even attempting? He said it would probably not work, but may be worth a try. If I have to drill a new well, I will trip a bunch of regulatory requirements that would be devastating and very, very expensive. Am I just out of luck or anyone have any ideas?
