Antique tub faucet name and safe remove
HandyGal
Mn
Hello, this bathroom has lots of old stuff dated 1929 up to 1980. I want to update this without damaging anything. What is this type of tub faucet called and how can I safely remove it? It's like half of a ball. The tub has no overflow.
Wow! You have three different handles there and I'm assuming that the water to the tub comes out where the overflow would normally be.
Is there still galvanized piping in the walls? And do you have access to the back of that wall?
HandyGal
Mn
Without some wall demo, I don't have access to the pipes. Yes, the water comes out where an overflow usually is. Hopefully this won't be as much of a nightmare as the toilet and rotten lathe style subfloor that was under it. It had ci rusted flange, attached to ci pipe with old lead and rope that had to be drilled and chiseled out (see below).
HandyGal
Mn
I'm wondering if this was some odd cowboy workaround changing it from a claw foot tub to what's there now. There's a bedroom on the other side of this bathroom wall, no access panels or anything.
HandyGal
Mn
Thanks! I'll check this out! So would you remove this faucet the same way as a more traditional one, then? The tub is in excellent condition and just needs elbow grease and replacement fixtures to look nice again.
Tuttles Revenge
A potential problem with that tub setup is that because the water filler is under the flood level of the fixture, it has no backflow prevention. I couldn't service it without fixing that issue either with some form of vacuum breaker/air gap or total replacement. I ran into one a few years ago and we couldn't access the fittings to separate the filler from the water supply. Ended up not doing any work in that bathroom.
I just found photos that may show the backside of that faucet.
HandyGal
Mn
I think I'll have to open up 1 wall to do this right. I was hoping at first to find a 3 knob fixture something like this and replace the odd round faucet, and even looked at more Victorian types of fixtures. I haven't found a 3 knob wall mount fixture that will lead up into an exposed shower pipe with shower ring, but that would be my 1st choice. I still have the problem of putting in overflow too.
Tuttles Revenge
If I were looking at this project as a professional estimator, I would advise against trying to reuse the tub with the filler as it is. The tub could stay, but the drain assembly and the water supply would be completely separated. I would rework the entirety of it so that the filler is a spout above the flood level. In the end you will have all modern working fixtures and a lot less potential of failure down the road. We have been installing a lot of external mounted shower systems. I think you're looking at the signature hardware site. I would look at what they have that is thermostatic valves.
something like this.
https://www.signaturehardware.com/b...pipe-tub-and-shower-set-with-hand-shower.html
I think a normal waste and overflow will work. replace all that with new p trap. then just replace your tub /shower valve with what ever you want. I dont think the valve you showed on the free standing tub is proper for this tub . but with 1100 dollars to budget plenty of choices around youll like I hope . why exposed shower pipe ? not sure they look good with this type tub
Marlinman
Jacksonville Florida
Your existing valve was made by the Crane Co. All of the valve parts and most of the trim are still available. An updated or modern trim would be a big challenge. Also the tub does have an overflow inside the waste fitting shown by Tuttle. The 2" pipe in his photo has a stopper and overflow pipe connected to the linkage going through the cap. Other than some new trim the tub wall or back wall will most likely need to be opened up to make changes.
HandyGal
Mn
Wow! They still make parts for these? That's amazing! I can't wait to look this up and see what they have! I was only looking at exposed shower pipe to hopefully not tear up the walls to add a shower. It would be nice to keep a vintage look to go with the bathtub and sinks which are all in good shape and look great with elbow grease. The kitchen sink may need a new strainer assembly (hope it's a standard size), but sinks are good.
Cool its actualy a combinatio tub fill/overflow. thought it might be. I run across tis old stuff rarely.
Did a major remodel on a 1920s mansion formerly owned by one of the Montgomery Ward department store founders in La Canada Ca. Some much of it orginal and in good condition really sadened me to demo it all out. the new owner had just purchased for 4 million and wanted it a little more liveable and new. but I hated what he did to his beautiful master bath. But the plumbers vote dosent count and it fed me for a minute.
Personal decision s for handy gal to make. not really right or wrong but pretty much permanant.
Big help to her Marinman Im supprised you knew it be Crane well should be serviceable if thats the route she wants
HandyGal
Mn
That would break my heart to demo stuff in usable condition! Imho, a lot of older stuff was made to last instead of wearing out and throwing it away. I want to keep any/all vintage fixtures I can because I like them. The sinks and tub has cleaned up beautifully! Hopefully the electrician would let me still use the push button light switches. I love seeing usable vintage stuff from demos being sold online to folks who will use and appreciate them. I hope you got some nice photos of the 20s stuff! I bet that old master bath was a beautiful work of art!
It was beautiful the new work was real nice too definately more comfortable . many good features .
HandyGal
Mn
I'm sure it was very luxurious, fit for a king. New features do provide a lot of comfort for sure!
Marlinman
The stem assembly is most likely to be the top one # LF480101. The valve seat listed is size 11/16-22 thread and can be removed with a 7/16 allen wrench. The handles are Hot # 147090 and Cold # 147230. Hopefully my handle attachment will open. These handles are exactly like the originals. From the photos the valve looks to be good working order.
IemaKxRbIBkq335F1nikA5fdA3PjxRKkpfG1IqP8k4UxMlD1SdctP6RJstX7_b40sp1zhv2AzXRV5cr5FpiRgXmpU-bm5Kdv_0qvj6lnfuFzdncaKdlh2Y6hXAROWN9rWasikA
  • [Untitled] (64).pdf
