ABS to PVC under new vanity
projectgirl
When my old vanity was removed, the plumber did not keep the old ABS trap. I now have the ABS piping coming out of my wall with the threaded elbow. My question is "can I use a PVC trap to connect the old plumbing to my new sink? If the answer is "no", what is your recommended action?
trap
1. The drain on the new sink is not likely to be in the same place as the old one was so you will have to cut that elbow off and use the adapter from the new trap.
2. Those elbows are not generic, so you will have to cut it off and use a different connection.
3. I ALWAYS cut those elbows off, since they are a very poor way to connect a sink.
So I guess what I am trying to tell you is to forget about that elbow, cut it off, and use the adapter that comes with the new trap.
Dubldare
Plumber/Gasfitter
MN/ND
...and that new trap will need to be ABS, to match the piping coming out of the wall.
Cass
Why does it need to be ABS? Why does it have to match?
As I understand it, without being a pain, if you are gluing things, you want to match the materials and make sure you use the right glues. If it is a slip coupling, it doesn't matter...
Cass
They have glue/solvent that will work on both PVC and ABS or a banded coupling may work to join the 2. If it is just for for the looks I understand.
Dubldare
Plumber/Gasfitter
MN/ND
Yes, but that trap adapter is the thing that has to match the existing piping.
While they do make multi-purpose (clear/amber colored) cements, they are not specifically for transitions. Transition cement is a god-awful green color, and hard to come by.
Codes differ everwhere. ND will allow one ABS/PVC glued transition, but only at the building drain/building sewer connection. MN requires a mechanical transition--female to male adapter, but most locales have begun to accept shielded mission bands for the transitions (since the orange sticker now states plastic to plastic).
All I know is that if I was to have any inspector around these parts see a PVC trap adapter glued onto an ABS pipe, I'd have alot of explaining to do, and I'd better have the saw ready.
Whether or not it will work is not for me to argue, or to give credence to. I'm supposed to know better.
Justin_NJ
NJ
transition cement
Found it in Lowes as I just used it last week... My house has ABS and the shower drain kit only came in PVC.
you can also use the clear stuff used for both pvc/abs. just be careful on the abs side not to use ABS primer - it will melt the pipe...
Shacko
Master Plumber-Gas Fitter
Rosedale, Md
Abs to Pvc
Where I live the use of universal cements has been banned for many years [they will leak]
A better install is to use a transition coupling
It's supposed to melt, the connection is called a solvent weld joint, not a glue joint
This is for information only, don't shoot!
"If all else fails, read the directions"
