2" PVC requires a core hole through a concrete wall
The_Optimyst
MI
What product should I purchase to sleeve the hole and what diameter hole should I request the core hole driller to place in the foundation wall?
Fitter30
Peace valley missouri
2" 2.375 " od
2.5" 2.875 1/4 " around
There's wet and dry core drills. dry lots of dust, wet a lot cleaner with a shop vac picking up the water, dead on hole. Only used a company to saw cut holes in foundation.
Slomoola
OKC, OK
One can rent a diamond core bit and a big papa drill at home cheapo. Or have an irrigation company that cores street curbs for drains come out and do this. Several options here.
Tuttles Revenge
The link that Wayne posted has a link to the sizing chart for each type of pipe. Here is the link for the PVC sizing.
But I'm not 100% certain on how to interpret their chart. Might be worth giving the manufacture a call to verify.
Its been a number of years since I've used these.
Fitter30
Need to look at a couple of you tube videos. Poured concrete diamond core machine and if there's a chance of rebar diamond core goes through it easier. Machine has to anchored to the wall, core bit is water cooled and amp meter that has to be watched to keep it a safe range with the pressure put on it.
