Gustave
Hello,
This is my first post. My wife and bought 10 acres in Paso Robles CA. We are now building a house.
The property came with a well and pump. The well report says the well is 500 ft deep and produces 10 GPM. I don't know anything about the pump, but the installed pump controller is limited to 2 HP. So I assume the pump is less than that.
We have installed a 10,000 gal galvanized tank on the hill behind the house, as per Cal Fire Code. It is 80 ft higher in elevation than the top of the well. I am about to dig a trench to lay pipe from the well to the tank. I am debating between 1-1/2" or 2" PVC.
At 8-10 GPM I am not sure if the friction will really be all that different. And I'm not sure if there are other considerations.
Any advice would be appreciated. Thank you.
Gustave
Gustave
